White deposit on oil filler cap
Hello
I've been looking to purchase an XK8 and viewed one recently.
I unscrewed the oil filler cap and found a pale white greasy substance on the underside.
The oil on the dipstick is clean and clear and smells fine.
Suspecting it may signify a head gasket problem, I mentioned this to the seller, a Jag main dealer who said he would ask their head technician.
Took the car for a test drive, had a look again at the filler cap underside and it was completely clear.
Oil pressure was constant and good as was the temperature.
The mechanic arrived, had a look and said he suspected it was simply condensation as the car has barely been used other than ferrying it a short distance to and from the workshop for various jobs.
The car seems well looked after and comes with a two year guarantee on a forty five thousand mile car.
What do members think? Do you think this could be a head gasket problem on the make and would you go ahead with the purchase? Or could it be simply condensation or something else?
Your opinion would be appreciated.
Hi David,
"Mayonnaise" on the oil filler cap is something us older drivers have seen before.  I have had it before on a Viva HC which my wife used for short trips.
It is probably condensation build up, but if here is no oil in the coolant I would not think it too dangerous.  It was in the VIVA for 8 years without a problem.
Thank you Peter for your response.
It's just a concern for me with that big V8 there and the possible problem I'm imagining
Thank you, Jim for your words.
I too am thinking the mechanic probably had it right and as you say, if the dealer is prepared to stand a two years guarantee behind the car, it's probably not something to worry about.
Thank you Jim, I appreciate your taking time to respond.
