I thought I would ask some of the people who are unbiased and might know the answer. My Jag engine waring light came on. After taking to a local garage they told me I needed to replace the cats. However, when I got home the engine waring light went out and the car drove perfectly. It does so even when the warnignlight is on. The engine warning light came back on, so I took it to my local Jaguar dealer and they told me the same that I needed to replace the catalitic converters.
That was a month ago and today I went shopping and when I retruned to the car and started it the engine warining light had gone out. Additonal fact sometimes the airbag warning light flashes and then stays on but on next operation the light stays off. I believe I have a wiring problem not a catalytic converter probelm. Has anyoner else experienced this type of situation.
The reason I ask is that it is a very expensive fix to change the cats, especially if that is not the problem. The car has only done 69,000 miles.
Jim
you may want to get one Jim did they give  you have the code numbers
if not mate you need to find someone to plug a reader into the car and get the codes off your cars system
ron
Ron,
Unfortunately, neither place I took the car chose to provide that information to me, only the fact that, in their words, I needed to replace the cats, and in one case, the lamda sensors as well. That was not the Jag dealer.
Jim Purdie
not being funny jim i would invest in a reader  ive just brought one off eBay just a cheap one for £12.50 as i had egr problems with mine and it read the cars dtc's with no problem,gave me the codes & what the problem was & even reset / deleted them it after.
saved me loads of money first time out of the box
ron
Dont get me wrong you can spend hundreds on one but for the DIY'ER i think a cheap or med range one is just as good
the plug & play version are ok for what i needed, you may have to set it up but that takes all of 2 mins and away you go.
there's loads of after market ones jim just make sure you get it right for your car.
 MS 309 £12.45p free p+p  is the the one i got for my x type diesel 2009, not 100% sure if this one will suit yours but loads out there
ron
