noise when turning right
Hi I have a 2004 x type drives great but when I turn right it makes a noise. Can someone tell me what it is
Any other clues Steve like is it only on full lock or what type of noise I.e. Squealing etc. Is it coming from back or front, near or off side?
When turning right with speed over 10 mph I think it is coming from the front passages side. The noise is like a vibration. There is no noise when I am pulling out at a low speed the noise comes when I am on a bend in the road.
Wheel bearing maybe
Thanks I will have a look and let you know
I had a noise like this, has it had any new discs or pads recently by any chance
mine had the metal disc shield which had been bent a bit and was nearly touching the disc, but when i turned it rubbed, could be something similar
