Hi was wondering if anyone nose how much and how easy it is to get and fit new wheel bearings in passengers front left side wheel any information will be nice
thanks shane
hi shane
just had a quick look on ebay, there about £50 to £60 and they look fairly easy to fit
wheel off , caliper off, disc off, four bolts and unplug your abs sensor
if you have a decent jack and decent socket set and about 2 hours start to finish. if every thing comes undone easy.
Ok thanks you I will have a look and think about doing it myself thanks for the help
How did you get on? I had to replace two on a Discovery 3. Sods to remove the old parts (on a taper) but an easy job apart from that.
Rog
Hello thanks for your help it went fine wasent that hard bit of a pain but can do it yourself
thanks
