Hi Guys,
im the lucky owner of XK coupe 2009 with only 50k km
but im unlucky as one day after purchasing the car( last week) when i was in traffic i got the signal engine temperature high ( yellow) and after engine overheat( red)
when i start moving with a car no more heat and all light disappear, when i stopped again the engine got overheat.
Did someone know what the general problem
please need your help
( my car is in QATAR, where the temperature is always higher than 40 degrees)
Reagrds guys
wajdi
Sounds like your electric radiator cooling fans have stopped working
get them checked
try not to overheat it too many times as it will damage the cylinder heads
personally if it were mine I would not drive it till its sorted
thanks
yeah instopped immediately the car, i dis not drove it after!
but which is sure that the fan is working because when inswitch off the engine the fan was working for minimum 5 minutes
my question is, if the problem is with thermostat sonwhy the car is not overheating when not stucked in traffic?
the temperture in Qatar is more than 40 degrees so the air is not fresh to cool the car
i asked a friend wirking in jag service center he told me may be i have to re programm the car?
is it true guys?
