indicator and headlight
hi i do not know if this is a common fault i came out to my 2008 x type 2.2 and found that the indicators and main beam have stop working i have checked the fuses and thay are all ok i am not a mechanic so do not know what i am doing.
gary, find a good auto election who will be able to trace what the problem is...
I suspect the indicator- and headlight lever at the left side of your steering column, or an interruption in the 12 V power supply.
