XF - 2014 Central Locking issues
Gemma1979
Hi, the battery on my smart key was low, so we have changed and tried multiple new batteries to no avail. I have now got the spare key which worked fine but then I had issues locking as it keep beeping at me as if the say the locking mechanism hadn't worked? All of the doors looked to be shut?
6 minutes ago, Jam106 said:
I have a 2014 model I needed the n/s rear door latch replacing then the os/f has been replaced today got locked out it won’t open at all can you oil the latch to ease this
I don't know if the issue has been resolved, however when replacing the battery, which is really easy, take care not to bend the contact prongs protruding from the circuit board when reassembling the fob. If you do the battery won't make good contact.
