Have just joined and looking for some advice I have a 64 xfr and yesterday turned my traction control off and as normal amber light came on dash but so did lots of other warnings such as abs ect and now cant turn traction control back on warning light always on along with other warnings any one any idea's????
Hi Wal
First port of call with the XF when you have any warning lights is to check the battery state of charge. These are VERY prone to all sorts of wierd problems if the battery is even a little bit dodgy.
From experience with the Saab 95 the usual cause of a christmas tree on the dash is an ABS sensor fault. I would try charging the battery if possible and then get the fault codes read.
Good luck
cheers for that will try battery first
