Steering Wheel Vibration
I have a big vibration problem with my 2007 Stype XS,tried all the usual things,changed discs,pads,all the main places to look,my garage is stumped,please any advice would be grateful.
  • 5 months later...
Have you checked the shock absorber bottom bushes ?
Tyres, tyre pressures, tracking, balancing and, as above. You should also check the run out on the new discs.
  • 5 months later...
A bent wheel is also a possibility.
I recently felt minor vibrations on my XF. I had the front tyres replaced with the Jaguar recommended Pirelli P zero, and I can really feel the smoothness now. Only problem is it now high;lights the vibrations from the back tyres which I now need to change!!!
This could be a possibility for your vibrations.
