Torque setting
Is there a torque setting and if so what is it please ?
For the rear anti-roll bar drop links.
Thanks Jim. Just got to figure out how to torque the four nuts with a spanner. Only have a torque wrench that is used with sockets. I guess you know it is not possible to use sockets, without turning the pin at the same time.
needs some thought. . . .
The force required is equivalent to a third of that for a wheel nut. So to give you an idea, loosen a wheel nut and tighten it to 42Nm to give you an idea of how much force you need to exert on the spanner.
Don't forget to retighten the wheel nut.
Crackin idea, thanks will do that tomorrow. Hopefully it will have stopped raining then.
