Vibration mk2 jaguar 240
Hi everyone ,I have a problem on a mk2 240 ,vibration through car when driving in overdrive only .Out of overdrive very slight vibration .All new tyres fitted and balanced
May be contamination in transmission fluid?
I see you are a new Member, welcome to the club Clivee🙂
Kind Regards,
Julie.
13 hours ago, Aubrey said:
Kind Regards,
Julie.
It only vibrates in overdrive ,it has ep 90 in the gear box
Hi there are a few things it may be.
CV joint / bearings possibly?
you can check this by seeing if any movement in the joint.
Kind Regards,
Julie.
