Posted (edited)
IMG_7492.thumb.jpeg.d5eb790f22d0c71a05ea54fb8ae5773e.jpeghi , I have a jag x type automatic 2.1 petrol, currently have a gearbox fault intermittent I have a cheap diagnostic test kit which I clear fault so I can drive it home without jerking and struggling. Was suggested to get transmission fluid changed or is it a bigger problem.
thanks
Edited by Stez
Show model
Hi Stez, I had the same problem although mine is a diesel automatic. I was advised to change the gear box Oil which I did and have not had any trouble since
Hi , glad to hear it worked for you , I will get that done ASAP 🤞 that solves the issue. Thanks 👍
I done some checking getting quotes wow ! Transmission fluid change and flush system £350-£500 inc vat 😬🤦‍♂️ wish I knew someone who can do it 🙄
