Here's a little top tip, not applicable to all Jaguar Models, but certainly quite a few.
It transpires that if someone uses the vanity mirror within the sun visors and does not slide the cover closed afterwards, the vanity light can stay illuminated. It should go out when the ignition is switched off, but if left on indefinitely, there is the potential for a fault to develop such that the vanity light stays on, even with the ignition off. Takeaway is to always ensure that the sliding cover is closed on the vanity mirror after use and not simply the sun visor flipped upwards.
N6 JMX
  • 5 weeks later...
Hi, just joined/re-joined, not sure, I have a 2000 XKR and after a few batteries and a kill switch, I think I may have solved my "drain" problem. After developing several niggly electrical faults, horn, alarm mirrors over extending etc. I bit the bullet and carried out a Hard Reset! Everything is now sorted, the battery can stand unused for 6 weeks without running and starts when bidden. Fingers crossed eh?
Miles
ScorpionÂŽ Vehicle Tracker Offer - Next Generation CAN-Bus Immobilisation
Disclaimer: As the club is an ScorpionÂŽ Partner, The club may be compensated if you make a purchase via ScorpionÂŽ links
