I have a low water fluid warning even though it's toped up to the limit.Is there a fix to this problem...and would it cause an orange warning triangle to be displayed.Any help would be great.
could be a sensorthe most likely culprit is a faulty washer fluid level sensor. This sensor, located within the washer fluid reservoir, may be malfunctioning and sending an incorrect signal to the dashboard. To resolve this, you'll need to have the sensor tested and replaced if necessary.  or thermostat related
Cheers mate..i'll check it out.
Scott.
Turned out ot be washer level sensor..ordered one from Jaguar..£20.98 including vat.
Thanks for the help.
Fitted today and working with no warning light...😊
