Does any know how to remove the sunroof liner, my lining is lose, and it would be great if I could take it out to repair,
but it looks like I might have to tuck it or remove the whole headlining, not something I want to do.
Help
Gary
Depending where exactly the material has come loose, you may be able to make an in-situ repair using adhesive carpet spray - hold the headlining away from the backing board (biscuit) and spray some glue onto the biscuit. Let the glue "flash off" then carefully and progressively fit the liner back onto it. I've used this trick on many cars over the years and it usually works well.
However, if yours is truly horrible, you may have to bite the bullet and take the complete headlining down.
