Hi my steering seems very sensitive at low, OK,  and at high speed, feels so light, not so good, I seem to remember that it's sensitivity dropped off on my s type 07, but only had car 3 weeks, 18 plate, 84000mls, can ti's be adjusted ?, thanks
Check your front tyre pressures and then if you don't find anything, check the front dampers (shock absorers) and front suspension bushes. Also have the wheel alignment checked - all of these things can cause the steering to go exceptionally light at speed.
