OK I am new to this S Type, but I have had one before, however this one has an annoying habit of beeping when at light or when I start off,
my assumption is that a previous owner replaced the front bumper and either damaged or blocked one of the parking sensors, all ideas welcome.
You can check individual parking sensors by having someone sit in the driver's seat, engine running and engage reverse, whilst keeping the car stationery on the brakes. You then listen / feel each individual parking sensor and you should hear / feel a ticking from those that are working. Any that are silent, are not working.
N6 JMX
Ideally you should hook up a code reader first to see what the car says. No need whatsoever to have the engine running to check the sensors. That advice should be ignored as it is inherently dangerous…….
No codes, showing anything, already checked 😞
