Hi, My 2002 S type has started to leak Oil from the head gasket...the nearest garage to me in The Czech Republic is 2 hours away..is it safe to drive for so long? will it burst into flames? is there a temporary cure that would last long enough to get to the garage?
thank you for any answers..
Kevin
Hi Kevin
Can you just clarify. Are you talking about and external Oil leak or an internal failure of the the cylinder head gasket? If an external leak it would help to see a photo....
Regards John
Forgot to say i believe it's an external leak, but curios why Oil is above the gasket line.
HI justin, sorry about the late reply, thank you for giving me the info, would never have figured it myself...hopefully it will be a cheaper fix, and thanks for the eBay connection.
do I need to buy and replace the 2 items you mention? or is it just the gasket ring?
thanks again,
best, Kevin
Only the gasket rings (2) I think you can just about access them without removing manifold casting. When you have one actuator removed, test it with 12v to check it's function and don't get the loom connectors mixed up between the upper and lower actuator.
