Is there a way to reset doors locking/unlocking , when i unlock the car using the keyfob all 4 doors and boot unlock , when i pull away the doors all lock as there supposed to , if a front passenger opens or unlocks his door he unlocks all 4 doors but if i unlock my door it doesn't unlock any other doors this is a pain if i need to open a rear door , they used to all open so have i done anything to mess the system up , the childlocks are not on ,any advice would be greatly appreciated,
        Lino
maybe a reset on the ecu would be a good start.... disconnect your battery for 10 mins... reconnect.
make sure you have required radio codes to hand.
this is good place to start.. if it is still faulty then you need to look into it further
Hi Steve
Im worried about disconnecting the battery, is it only the windows and radio code i need to worry about if i disconnect or does anything else need to be reset
    • Jaguar Icons
      • 11 replies
