Hi, I'm new here and looking for a few pointers. I brought a 06 x-type estate from a garage and was very pleased with the car......until the dual mass clutch went some 150 mile later, the car was taken back and the clutch replaced under warranty but when I got the car back it had a very annoying starting problem. Sometimes it would fire up with no problem and another time it would start but seem as though it was only running on two cylinders and no throttle response. It would take several attempts to get it to fire up correctly. The car has gone back to the garage and they say that they are replacing the injectors, but I fear that they are scratching their heads a bit trying to find out what the problem is?
Can anybody help to throw some light on the possible solution.
The car is a diesel turbo 2.0 ltr and has done 116k
Henry. (Road wolf)
HI HENRY
did it run ok before the garage had the car in for the clutch?
is it a jaguar garage?
do you have any warning lights on?
TREVOR
Running fine before the clutch was replaced, and no it is not a jaguar garage. The engine management light goes off when it starts ok but remains on when the engine is running on only what seems to be two cylinders, also when problem is apparent there is no throttle response ( fly by wire throttle)
ok my car run much the same it was a split intercooler pipe on mine
you need to look for that and at the same time clean the egr valve
TREVOR
Cheers trev. I will pass the info on to the garage just in case they have not checked these things.
hope it works  for you when the car is back to running right
it will pay to blank the egr off done mine and done another today
good luck
 TREVOR
