lots of codes and lack of power
Hi all, lots of fault codes as you can see and a lack of power 0-60 in 15 secs, this is the 2.5 Indianapolis. Also a complete loss off power at 3500rpm, only seems to do this in third and forth gear when the engines hot. I imagine not all these fault codes are the issue but one of them is causing the problem and making them all show up?
post-6612-0-15624400-1425245741_thumb.pn
Welcome to the club, Chris.
I think that an expert is needed here,  and I hope that the issues get sorted.
It sounds quite complicated, but if you can get to the root of the problem the other matters will be solved.
Peter
