4.0 litre misfire
Timothy Ashtray
Hi Tim
Could be one of many thing really, Have you checked for any fault codes?
If I were mine, I'd start with a new set of spark plugs, but also it could be a coil pack
if you change the plugs, they should be a nice light brown/tan color, if you get one plug that's black/sooty that could be the problem one
if plugs don't cure it and you are getting a odd colored plug compared to the others, swap the coil pack with another cylinder and take it for a run and see if the dirty plug shifts to the new position
also check the coil pack connectors for corrosion, this can also cause this
