the rubber strip around the driver door has spilt and the crack is getting longer.
Is there any way to either replace the rubber, or fitt some form of kick plate to stop it happening.
do you mean the door seal, post some pics up
if its the door seal, it can be pulled off and replaced, there should be plenty on ebay
Yes, that's it. Door Seal. "...it can be pulled off and repleced" sounds too easy.
there's also a little plastic trim you have to remove as well at the bottom, on the door step, but it just unclips
it should only take ten mins to change
I've replaced mine, it is easy, when fitting the replacement it seems like it is too long, but it will fit with a bit of persuasion, ie, give it a good thump with your hand to get it to seat properly.
