Noisey thrust bearing i hope
Ok i have noticed that the wifes car makes a noise when first pulling away ( she was oblivious to it ) bless,
so gentlemen should i take the gearbox off just to look  option 1
let it be till it eventually get louder  option 2
Option 3 replace complete clutch and thrust bearing dont know if its a dual mass flywheel,  having never owned 1 before, but with my good friend and his ramp we are able to fix it
It only makes the noise on pulling away and goes through the gears great and does not slip when i let my right heavy foot relax when slow cars are in front , yes to my shame i have to see how the car overtakes the slower cars, not owned it long enought to be bored with it.
so hoping its the cheaper non dualmass flywheel  and because they are a pain  im thinking option 2 although my mechanical side say change it save more work,
oh yeah 1 more option jst change the thrust bearing and look at the wear on clutch.
car will be going on holiday soon to bognor and i will follow up later in my little car, will say what it is and put up with the well thats a hair dressers car Mk1 mx5  or as the yanks call them miata.
When does it exactly make the noise
Thrust bearing will make a noise when you press the clutch pedal only, also a noisy thrust bearing can usually be felt through the clutch pedal when pressed
dual mass flywheel can make various noises, usually a continuous noise when running/idling, can go quiet when revs are raised and some times they go quiet when you press the clutch
to do either, the gearbox has to come off, so if you thinking of do any, both should be done at the same time, including the thrust bearing
not sure if these do have a dual mass flywheel, but most diesels have, its a way of eliminating vibration on diesels
but if you were thinking of changing the thrust bearing only, you have to remove the gearbox, so while it off, its a ten minute job to remove the clutch and check it and once you've removed the clutch, the dual mass flywheel is there right in front of you, just check it, basically the dual mass flywheel is made up of two parts, the centre and outer, between the two parts is filled with rubber, the rubber fails and perishes, so the outer becomes loose and will vibrate, it should be visable and you will feel movement in it if its starting to fail
what year is your car, petrol or diesel, that might indicate whether it has a dual mass flywheel
P.S. on your car the thrust bearing alone can't be changed, it has a concentric thrust bearing
so pics and prices, these are a guess as not sure what engine you have
https://www.britishparts.co.uk/products/10838-slave-cylinder-C2S46903
https://www.britishparts.co.uk/products/6120-flywheel-C2S27921
https://www.britishparts.co.uk/products/135156-clutch-kit-JDE4964
2.2dse 6 speed manual and it only makes the noise when you put you let your foot of  when first pulling away from stand still or when reversing so only when releasing the pedal to engage the clutch fully, and not heard when just changing gears.
So just when first pulling away and at no other time and no vibration is felt .
that does not sound like the thrust bearing
sound like something else, like some thing rubbing or dry, or even something like maybe a engine mount
I will have a look i did notice on the engine cover there was signs of rubbing so when it get it on the little scissor ramp we have i will look at the rear one and check the others,as well
thanks for your prompt replies im in no way a fully trained mechanic but between my good friend and myself we do wrok on cars so we will have a good look over the car,  and i am rebuilding 3 classic cars well 1 really classic MM and 1 mk1 fiesta, and a mk2 vauxhaul nova,
If it were thrust bearing it would make the noise every time you press the clutch
sounds like you have plenty of projects going on
let us know how you go on
joe
