Hi All
i was outside topping up water / oil / putting air in tyres as you do, then i noticed this!
here is the detail.. for a couple of months there has been a slight scraping sound from out side which i initially thought was coming from the gearbox tunnel,  but my good lady said yesterday it was from her side towards the front. its not a constant sound, sort of like this if you can use your imagination scrape - pause - scrape - pause - scrape - pause etc the faster you go it then just becomes a constant sound (albeit its not horrifying enough for me to be overly concerned) and tends then to disappear, with the sound of engine and wind noise,
Anyway....
i have checked the inner walls of the tyres and they seem fine, there is no obvious smell of over heated metal or burning etc when i stop, there does not seem to be any obvious signs of uneven wear to the front passenger tyre. i did clump the kerb about a month ago at the front end, i had to mount it to pass a dustbin lorry that was mostly blocking the road.
however the scraping sound was there before that. have i bent the tracking rod? is it an MOT fail? is it expensive to fix - replace? and finally should the steering wheel be horizontal with the wheels in the straight on position? sorry for the multiple questions, oh and just to add, there is a slight pulling to the left, but i put that down to low tyre pressure and 'Ruts' in the road on the 'B' roads i travel on every weekend, it seems to be fine on motorways. just to mention there is a difference in alignment of about 2 1/2 inches from body work compared to drivers front tyre (unless the body has twisted :w00t: )
as always any advice greatly appreciated
Thanks in advance
regards
2087212889_steeringwheel.thumb.jpg.8bf1446b7e72af5d5ac7693a34606221.jpg954510998_driverswheel.thumb.jpg.560af9c6076700e0fe066e6cca457d10.jpg1402530812_passengerwheel.thumb.jpg.751eb44d2b6aa13d26df9165657ae8d1.jpg1696068028_driversfront2.thumb.jpg.db6712670cae143a936f23a484c63b51.jpg295489071_passengerwheel2.thumb.jpg.592390e72851407fff967cc6bb7206c9.jpg
cheers Ron, didn't even consider that! what's your thoughts on the alignment issue?
thanks, i can honestly say i have ever compared steering wheel alignment with wheel position, but when the MOT is due i will get them to check and adjust as required. hopefully i didn't do to much damage, although i chipped the concrete kerb i was only traveling about 5 MPH i will report back after the MOT
Many thanks again Ron
