6 Speed Manual Transmission oil 2.2D
Hi Guys. I have that feeling that my transmission might be low on oil. Gear shifts are okay but not as smooth as it should be. I have a 2.2 diesel X Type 6 speed manual. I came across a few videos on youtube for the v6 x type and that gearbox takes 1.75 litres of oil. I would like to know how much oil does the 2.2 diesel 6 speed take and what kind of oil should I use.  Thanks in advance for the reponse.
Hi Roger according to my haynes manual, your gearbox holds 1.75 lires but I`m not sure of the type of oil. my car is automatic. maybe halfords will be able to tell you.
Rod
Hi Roger !
according to commas product finder capacity is 1.75lt and the product code is MVMTFP1L fully synthetic transmission fluid, hope this helps.
the oil should meet spec WSD-M2C200-C and grade 80w90
put the spec in on ebay and you can even get the genuine ford oil
