2008 parking sensor module
Hi guys,
my parking sensors don't click and I get the long 3 second beep when I select reverse.
From my reading up, it sounds like the module
The numbers on mine are 4X43-15K866-BG
underneath that is VALEO-601.841
Germany
HW02 SW04 CODE01
29 05 08F/2/11/91
0814917684
I'm finding similar numbers but not the same. What am I looking for
thanks in advance
Hi Martin, I have the same model, same year and same problem. I will check my numbers to see if I can find the same unit.
Rod
Rod
thanks Rod
Hi Martin, Just looked at numbers on my car.
4x43-15K866 BG
A 12068572
VALEO-601.841-GERMANY
HW 02 SW 04 CODE 01
30/11/07F/3/11/56
0733411786
Not sure but maybe the last number is a part number. I will try following this and see where I get to.
Rod
Hi Paul, Mine ends in BG. Many thanks , I will follow this up.
Rod
yep mine ends in BG too
thanks Martin.
Rod
