Bluetooth, power socket and CD changer.
Hi Paul, I've received a CD changer. hopefully it's the final piece of the puzzle. i would be gratefull if you could give a briefing on fitting the Voice module, Bluetooth module and CD changer before I jump in and have a go.
Thanks.
OK Dean, using the modules, locate the connectors in the luggage area loom.You will find that the voice module will not be fully populated.
Install the modules where required on the Kaiser panel. This is the large sliver coloured plate which is bolted to the side if the luggage panel. I'll see if I can find some helpful pictures.
Disconnect the D2B connector from the NAV unit and plug it into the extra portion of D2B cable. Connect D2B to each module, there is no specific order.
Mount the CDC in the rack and make sure each module has a power cable and D2B attached.
Connect the aerial to the bluetooth module and locate the aerial at waist level in the trim so it can't be seen.
That should be you ready to go 🙂
I've just googled "X-type voice" and "X-type bluetooth" and there are loads of pictures you'll find useful.
PM me your e-mail address and I'll see if I can find some detailed instructions.
