  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Passenger side front control arm ball joint
As can be seen from the photo attached the boot around the ball joint at the end of my control arm is looking perished. My question is would this be a quick case of undoing the nut below it, sliding off the old rubber boot and putting a new similar size one on like in the other photo Ive attached and doing the nut up again ?
yes , if once the ball joint is split, and the ball joint has resistance, not sloppy, so the ball joint is not worn out
then its serviceable, new boot and grease would save it
