2004 XJ8 4.2 Suspension Collapse and Speedo Stops working
Hi,Suspension drops but is still driveable but bouncy and the speedo drops off,anyone come across this before?Thanks
anyone recommend a more technical forum or Jag specialist in Scotland?
Hi Alvin, did you sort out your air suspension problem. I had an issue with my air suspension (XJ8 X350 - 4.2) which was initiated after dropping down a crater! in the road, which was hidden from view, but anyway after this tremendous thump the air suspension warning light came on intermittently. Eventually the problem was diagnosed as a weak air suspension pump and it has since been replaced. What happened with your problem? Anthony (new member)
I HOPE THE COUNCIL RE-EMBERSED YOU.
