Hi everyone,
driving down the motorway today my EML came on. Car is 2.0D 2017 125000 miles
booked in to Halfords next to work to at least diagnose as no other symptoms and they read the following codes:
p2BAE-00 NOx Exceedance
P25A9-13 piston Cooling oil circuit/open
P049B-00 Exhaust Gas recirculation
like I say no other symptoms. Had a google of these and a few different things come up as expected. Not clear which one triggered the EML but seeing things from Ad-Blue sensor mucky or failing
piston solonoid failing or more onerous the timing chain is loose and cause this error. I know Inginium engines have timing chain issues so one to monitor but don’t have a low oil warning or any issues with oil level?
The garage reset the codes and they didn’t come back on but I’ve bought a carissa monitor so can at least monitor what comes back up more readily.
Also bought some wynns fuel and ad blue cleaning incase it is just mucky sensors.
Any advice on what to check or keep an eye out for? Like I say 125000k miles so wondering if I should be looking at timing chain replacement regardless 🤔
Hello. I am new to Jaguar and this club, living in North Hampshire. I have a 2017 XF 2.0 D,  Recently need timing chain replacement including upgrade to prevent a recurrence. Fortunately covered by dealer warranty.
Prior to negotiating the repair I funded a test £200 + vat) on a main dealer rig to know for sure if new chain was needed. Result was clear.
Engine now sounds better and seems a bit more responsive.
Sorry this may not be of any real help to you, but the failed test result came with dire warnings of possible outcomes if the job was not done. I expect you are aware of these.
All the Best and Regards, Brian C
  • Like 2
