I have a water leak coming from the back of the engine , my local garage says it’s an engine out job , any thoughts ? It’s an 08 2.7 luxury
  • 4 weeks later...
I had the same problem, there is a water hose at the rear of the engine which you can reach from under the car if you remove the engine bay floor pan. Tricky but doable.
