Evening All,
I have a rather nice new to me 1989 XJ40 arriving early next week, the seller told me the tyres on the car are still the original tyres supplied new with the car in 1989! He reckons they are still in great condition but really i dont think i should be considering using them at all.
So, i tried all the usual online tyre sellers plus our local tyre dealers only to find that replacements for the originals still on the car are just about as scarce as rocking horse.......
The originals on the car are DUNLOP 220 / 65 / R390
Can any of you good people out there help in trying to steer me in the right direction to find some replacements.
Thanks, Paul.
15 hours ago, Freebird Paul said:
Evening All,
Thanks, Paul.
Hi Paul, this website may have the information you need or even the tyres; https://www.longstonetyres.co.uk/classic-car-tyres/jaguar/xj40.html
Hi Paul, your problem is the fact that your "new" car is fitted with metric sized wheels, which was somewhat of a failed experiment back in those days - mostly affects BMW.
As the other "Jim" has outlined above, you should be able to get replacements from Longstone, although you may have to wait on incoming stock. Quite rightly though, you should not be driving on tyres manufactured in the late 1980's.
Hi Paul
Given those tyres are likely to be north of £600 per corner (when you can get them!), unless you are desperate to keep the original wheels I would be looking to replace with a set of 15" or 16" alloys which will probably cost a lot less that the R390s.
https://iconicalloys.co.uk/
https://www.imagewheels.co.uk/
Good luck
John
EVening Jimbov8 / N6JMS / Big John
Thanks to you all for your helpful replies. The end result i wanted was to keep my perfect condition Teardrop wheels at all cost.
After several days trawling the web it all came down to a big Zero.
However I eventually searched the correct size AVON Turbo Speed 200/65/390 used but having 5-6mm left on them. So All well that ends well.
Thanks again to all
If memory serves, Jaguar made some Imperial (normal) size wheels for the XJ40 in the same style. If you keep an eye on ebay for a set of 16" Jag wheels, you should eventually come up with a set. Then you can have them refurbed and new 16" tyres fitted.
Check the manufacture date on your Avon tyres, if they're over 5 years old i wouldn't use them at all. I had a brown trouser moment in my S Type not long after getting it when the steering failed to respond due to the (near new in terms of tread) Pirelli P6000 just did not grip - they were ~10 years old at the time.
I now run a set of new Maxxis Premitra HP5 tyres, similar to the P6000 in tread pattern, feel and probably better in grip having driven on new P6000s some years back. Would definitely recommend them!
Hi Paul
Personally I would be moving to 15" or 16" as those tyres will simply become less and less safe the older they get, until at some point they will fail........ :(
Found this which appears to be the 15" version of your metric wheels. Might be worth a try and see if they will ship to UK....
https://susuperdeals.shop/product/75661006133/?cid=803cf2e9053a846b4d3f76833657f3ff
Good luck
John
Thanks for confirming my memory John! Searching the part number on ebay UK, i found these :
https://www.ebay.co.uk/itm/157386222514
Probably less than the cost of one metric tyre! Bit of a hike to Brum to pick them up but often people have networks of friends on various fora that can offer a pick up and delivery by passing to various people along the way or there's even Shipley.com.
It works out that 225/65/15 tyres are very close to the original size (overall diameter 676mm original, 674mm is diameter of 225/65/15) and i daresay a set of 225/65/15 tyres plus the cost of the UK 15" wheels from ebay would be close to about 2 of the metric tyres without the need in a few years to repeat the hunting exercise.
https://www.ebay.co.uk/itm/306346687269?_trksid=p4375194.c102726.m162918
https://www.ebay.co.uk/itm/127169141692?_trksid=p2332490.c101875.m1851
Second link looks to be same wheels but payment in Euros which seems cheaper!
Even with the cost of refurb these look the way to go if you want to actually use your new toy and not simply look at it on the drive 🙂
Good luck
John
....also I would check the age of your "new" tyres. Code for date is last 4 digits following DOT on the sidewall, first two are the week number and last two the year. So 0101 would show tyres made in the first week of 2001.
If your code is 3 figures they are older than 2000 so are downright dangerous!
https://btmauk.com/2021/01/26/dot-code-celebrates-50-year-anniversary/
John
