Hi one headlight too low adjuster's not working so failed MOT so orderd from EBay new lifetime black parts for £9.99 undue bumper under wheel arch cover two ten mill bolts removed light it's hard to undue the stupid wiring connector,then hubby used a heat gun on the glue on the edge of lens or you can warm it on top of the stove,with the lens off you can see the broken parts that need replacing easy but don't remove the old glue reheat and then press it all back in place refit back to car fit all bolts back and front wheels adjust lights.as required
job done you have a cheap fix happy motoring
Useful piece of information, Chrissie,
What can be a small thing can often cause a big problem in the MOT, and if you go to a main dealer an hour's work to fix a such a problem can cost an hours labour priced at about £140.
