Is there a fuel pump in the tank on the 2.0 deisel ?
In the fuse box in pasenger side theres a fuse f17 which is for the fuel pump module and relay what does that actually control ?
You have not said what your problem is ---fuel pump not working etc--- is you fuel filter OK ???
here is a part of the manual that pehaps help'????
The fuel pump is located under the intake manifold and is driven by the timing chain at the front of the engine.
The fuel filter is located at the top of the bulkheadon the righthand side of the vehicle.
There is a fuel pressure sensor on top of the engine.???
I should imagin the fuse is to do with that .I will try and find out.???
Frank
Had a new injecter fitted to number two cylinder and also had a new filter and system bled but still wouldn't start then fitted a new cam position sensor and still no start
Number two injecter was changed because it was diagnosed as being stuck open/overfueling by AA all three remaining injecters were ok.
When trying to start---Does it fire at all or just nothing???? --is there any smoke from the exhaust
when its turning over ???? Is it getting any fuel at all to the injectors .???
???-If it was over fueling on 2 there must be fuel + smoke .???
Frank
Changed no 2 injecter new filter and bled the injecters along with a new cam sensor
Tries to go but just wont and a little grey smoke
Got a diagnostic chappie coming tomorrow cos i'm just getting nowhere at the moment
He's going to recode the injecters
Does the injection pump have to be code like the injecters ?
