I have a 52 plate X-Type 2.5 V6 AWD and need to change the OSR wheel bearing assembly.
Would anyone be so kind as to tell me the correct socket size for the hub nut? I don't have a manual.
Thanks in advance
Hi David
I checked and cannot find the hub nut size I will try again "BUT" you do know that
after you have removed a hub nut you should always replace it with a new one
because it dosn't lock properly the 2nd time .?????
New bearing ---New lock nut .???
Good luck
Frank
Hi David
I looked at a few new AWD rear wheel bearing assembly kits and most have a new nut supplyed ???
Frank
Hi Frank,
Many thanks for the reply. Almost a tale of woe.
I bought a new hub bearing kit (it's made by Lucas) but it didn't come with the nut, so I also bought the nut, which Is 30mm. I bought a 30mm impact socket from Halfords after the nice chap assured me it was the right one, but it doesn't seem to fit the old nut on the car. I'm assuming it's 31mm or 32mm, but either way, it needs to be deep/long reach right?
The old nut has a castellated style top, whereas the new one doesn't, but does have a integral washer.
I've searched the tinternet and just can't seem to find any reference to the correct nut size or socket!
Hi David
I looks to me that the old castlated nut has been updated to the new type nut .???
Its late now but I will try and help more tomorow.
Frank
Frank has given you great advice about the new nut, make sure you use a hex socket to remove and re-tighten the new nut.
Using an Hex head socket the size should become quite obvious I would have thought having, no free play.
Ken and Frank,
Thanks. I will get one at the weekend and report back.
Best regards
David
Just for info. 30mm socket arrived today. Doesn't fit. It must be 32mm. I think I'll give up!
Hi Guys.
All confirmed. The hub nut is indeed 32mm. You need a deep socket.
