Do you think this is genuine Joe ? looks to easy to me . Had mine done last year and quite a bit of effort went into it by a mobile headlight restorer . If it actually works that would be fantastic . It would be interesting to see if anyone has used this product .
Regards ,
Andy .
Not sure but there's a few clips of people using it on youtube
maybe some one will try it,  but it would be good if it works
most headlights lenses are made of a polycarbonate type plastic, so the right chemical would clean it, like the first wipe they use, second wipe might be some kind of sealer
if I see it listed over in the uk, I would be tempted to try it
Just ordered the same as GaryE from Euro parts.
I couldn't get your code to work though, but found another one for 30% off VBOX741
We'll have to compare results.
The wipes arrived , not as easy as they make out, 4 hours to dry. If your light surface is rough it needs sanding with 2000 grade wet and dry first. Luckily mine were in fairly  good condition just dirty
before
After
    • Jaguar Icons
      • 11 replies
