Windscreen wipers won't stop..
Kenny s type
Hi all has anybody had a problem with the windscreen wipers not stopping here's what I've tried so far
Cleaned up the fuse
When fuse is removed they stop
Disconnected wire at the switch and they don't start but if you disconnect the wire at the switch while they are on they don't Stop?
When they are on if you follow them with your hand and try to stop them in the position they should stop in and hold them briefly they stop....
Could the motor be overrunning ?
Any Ideas would greatly be appreciated as I'm no electrician
Cheers in advance
Kenny.
Ive had it before on other cars, not the s-type
they have a switch on the wiper motor, that gives it its park position, usually its all greased up and Ive found on a couple of cars the grease dry's up and stop it working correct
all I did was clean the contact up with wd 40 and then re-apply fresh grease
but on the s-type its most probably just as easy just to replace the wiper motor
