P0753 Shift solenoid A
Hello Folks,
My names Dan and I'm a new Jaguar owner. I recently bought a 2007 Xtype 3.0 auto. I bought it through Copart so it has some issues. 1 of them is the P0753 fault which torque pro lists as shift solenoid A. Would anyone have a part number for shift solenoid A? Thanks in advance for any help.
Dan
On 12/31/2017 at 1:15 AM, Mark from suffolk said:
Thanks. Im going to try the fluid first. I was going to pull the engine and trans out to put in a different project so I drained the fluid. I kept it in a clean container so I could reuse it. But with pulling the actual drain plug only about 5 quarts came out. According to what I read googling fluid capacity its supposed to hold 8.8 liters which converts over to about 9 quarts.
The car shifts from 1st to 2nd. It doesnt shift smoothly though. I think it may be going into 3rd but Im not sure. The red light that looks like a gear with a ! In it comes on and thats all it will do. I pulled the codes from the computer and it popped up the shift solenoid A fault. However I didnt give thought to the fact it just didnt have enough fluid to build proper pressure.
On a good note though if that doesnt fix it I found the solenoid to fix it. Thanks again
Dan
from that fault sound like the solenoid is faulty
according to the code open circuit, there different colors you need to find out which one it is
I take it its the ZF 6HP26
also the solenoids can be changed by just removing the sump/filter
removing the sump/filter will also give you a idea of the condition, if oil is clean
they can be bought off ebay individual or in sets, either genuine or aftermarket
6 hours ago, JOE-DOT-COM said:
Thats why I was looking for a part number when I posted this. Its just the 1 solenoid popping up an error. If it were fluid I would expect to to effect them all. I have no real clue though and ATF isn't that expensive to check. It's not like royal purple in the cougar costing 20-24 bucks a quart.
I found the entire solenoid set on ebay for around 105 bucks though so I may go ahead and swap them out first anyway. As far as Im aware they have 266K miles on them so it may be time anyway.
if its the ZF 6HP26, you need special oil, it has to be ZF Lifeguard 6
you can't use normal ATF
the TCM for the gearbox, is actually inside the gearbox, submersed in oil, using the wrong oil will damage it
also the gearbox holds nearly 11 litres of oil, dropping the sump/filter will only drop about 6.5 litres ,the rest stays inside the Torque converter, so mixing oils is also not a good idea
thanks
joe
ZF - TechServiceMan.pdf
ZF6HP26_Transmission.pdf
3 hours ago, JOE-DOT-COM said:
thanks
joe
Unless those are all generic photos mine doesnt look anything like that. Thats a rearwheel drive trans. I have a transverse mounted drivetrain so it looks just like a front wheel drive trans. And I believe is a variation of the ford CD4E trans.
thanks
joe
I've been googling to no avail. How do I tell what trans I have?
you can put your vin number in on jaguar topix and the cars spec should come up
is it a 5 speed or 6 speed
2 hours ago, JOE-DOT-COM said:
I bought it wrecked and am working on getting it back on the road. The first time I drove it is when I discovered it wont shift higher then 2nd or 3rd. All I can say is its a 3.0 automatic.
Dan
HI
looking at yours, it may not have the zf gearbox
look at the J-gate gearchange, if it only goes from 2 to 4 on the left hand side then its a 5 speed and not the zf
the zf box on the left goes from 2 to 5 on the left of the j-gate
if its the 5 speed then normal atf can be used and parts are cheaper as a rule
JF506E_UPDATE.pdf
Jaguar Workshop Manual X-Type 2001-2009.pdf
5 minutes ago, JOE-DOT-COM said:
HI
JF506E_UPDATE.pdf
mine stops at 4. So yay regular ATF it is. Thats good to know, i was worried for a second. Looking at some videos though on youtube I found one guy was having a similar problem with his and it turned out to be a faulty ABS module causing issues with the rest of the system. Im also getting a fault for both front ABS sensors, Im wondering if that could be an issue as well.
Dan
abs sensor failure can cause lots of problems on some gearboxes
some gearboxes rely on abs sensors for speed reference and can make them very irregular and jerky gear changes
I would start with fixing the abs first
7 minutes ago, JOE-DOT-COM said:
Yeah I'm looking that over when I get home if its warm enough in the garage. Thinking back to when I had the front end apart I may have forgotten to plug the ABS sensors in. Silly me. It would be nice if it really is that simple. If not I have enough info with the links you posted that I should be able to figure it out. Thanks for those.
Dan
