hello guys I have a jag xf 2010 I wonder if anybody has experienced this' when I brake sudden my brakes are ok.but the longer my foot is on the brake pedal the less efficient my brakes on the car are the brake pedal goes hard to press.not sure if or when the brake fluid if at all has been changed any ideas many thanks the cars millage is 146300
sounds like a dodgy brake servo, was a very common fault on the S-type Diesels
same engines and servos used in a lot of xf's
worth checking the vacuum hoses as well, just in case ones split
the S-type servos that fail, get contaminated with oil, which causes the diaphragm to fail
