Hello,
I have a warning in the centre console that my brake pads are worn so I bought a set of wear indicator prepped Brembo pads to replace the old one with.  Ready to start the job I started looking for the locking wheel nut adapter with no success.  My car has no spare wheel and apparently no jack (not a problem as I would be using an hydraulic jack), but the only mention of location for the adapter is beside the jack on top of the spare wheel.  What I have is the Jaguar tyre inflation kit in place of a get you home spare wheel.  Does anyone know where the wheel adapter is on models with no spare get you home wheel?  I guess we all need to take the wheel off sometime if only to change tyres so there must be one! I guess!
JackC
Hi Jack, and welcome to the Club!
Mine was in the centre storage box when I got the car, though that may not be where it was supposed to be!
Hi Jack, have a look in the spare wheel well in the boot. There should be a foam carrier on the left side which should have the lock nut adapter in it.
I have the same setup on the XF and its in the boot. hope this helps if not to late and already found
