Gearbox fault showing on dash car drives ok, but no reverse lights or parking sensors, when manually selecting gear car drives in full auto mode. anyone???
Hi Dave
You would be better to check for any codes, as it's probably nothing to do with gearbox.
Any code that shows up delete it and then see if it comes back on,as it'll save you money in the long run.
Regards Tom.
There is a reverse light switch on the top of the gearbox, this is probably your problem. Apparently easy to change
you need get codes read, also generic code readers only read engine fault codes
it could be one of many things like abs sensor, best to get it read on Jaguar IDS/SDD so it will show all faults on the car
Used OBD Reader at the weekend had 2 codes stored P0743 Torque converter clutch circuit electrical & P0915 Gear shift position circuit range/performance
any ideas where to start
Looks like it's the water ingress problem, removed the TCM today and the circuit board corroded and pins corroded, cleaned everything and will test tomorrow, mean time better get on Ebay
Hi Dave,
Can you post a picture of the offending item - I'm having similar issues with the wife's 2.2D Auto and it maybe the same issue as yours.
