Key fob buttons not working
So recently bought a car and the sale went quite swift but had no reason to use the key fob till I was home turns out it won't lock and unlock nor will the buttons inside the car the only button that works is the one for lights any help  out appreciated
  • Sad 1
If you have just bought the car I would get back to the dealer and seek his help in curing the problem or replacing the key fob.
Good Luck and Best Wishes, Regards, John
14 hours ago, ScottyXF-S said:
been doing some research i dont believe the fob is at fault as the car wouldnt start without it ill go to a JLR tomorrow if need
That will cost you an arm and a leg. key Fobs are advertised for sell on eBay. That may be a cheaper way of proving if it is the fob.
Regards, John
well ive found a local place called the jag centre in norwich. cars booked in with them for diagnostics at £75 free courtesy car too and wont carry out any repairs with out discussing the problem and costs so see what happens
