What are "performance" brakes on my XKR?
Hi Terry,
Found this - the link takes you to site showing examples
Julie.
Jaguar Xkr Brake Discs Performance brake discs are an essential upgrade if you are increasing power, or if you just want a more positive pedal feel and better braking performance. We have a huge range of drilled, grooved and combination disks to suit all tastes, and one things for sure, they will all stop you better!
www.dcperformance.co.uk/improve/performance-brakes/brake-discs/jaguar/xkr.
Performance brakes or racing brake are the Brembo brakes that were fitted
same brembo racing brakes as fitted to my S-type R
25 minutes ago, JOE-DOT-COM said:
Incorrect information. Wrt to the brakes, I haven't come across 5.0 XKs with the 5.0 XKR brakes as standard. The sizes are noticably different 355mm to 380 mm at the front. I think the rear is an even bigger difference.
It is possible that:
  • Performance = 355 mm (taken from the 4.2 XKR)
  • Super Performance = 380 mm (standard on almost all 5.0 R models without carbon brakes)
Just measure them and it should be fairly clear what you have/need to replace with.
Non of which are Brembos.
Thought this depends on which engine, does not mention 5.0,
just assumed it was a 4.2, which did have brembo's
but should of realised as its a 2013 car
