working on a 2002 doing engine swap and the oil cooler hoses going into the oil pan are to big for new engine, cant find the smaller hose ends. any ideas how or were to find the smaller hoses
if you cant find them, the hoses usually go to the oil filter housing/base, can you not swap that part so you can use the original hoses
which engine do you have
4 hours ago, JOE-DOT-COM said:
if you cant find them, the hoses usually go to the Oil filter housing/base, can you not swap that part so you can use the original hoses
We can, but don't know if the base internally is the same and trying not to since the motor is in the car, its about 10 hrs.,  of more shop labor to repull the motor to attempt the swap. Its just the 4.0 none super.
    • Jaguar Icons
      • 11 replies
