Hey guys,
am new here and thought I would seek your advice, I have always loved the S Type and went to go and have a look at 2003 3.0 V6 to find I couldn’t fit into it at 6’9”, the seat just doesn’t go back far enough, is there a way to extend the runners or remove and place further back to accommodate me, the only bummer is that I can’t test drive one. I dont care about the passenger behind because this is for me, my tiny wife and daughter who can sit behind her. I see the latest post 2006 models have a longer wheel base but then it’s falling into the stupid tax category. I don’t know if anyone else has this problem??
Thanks for your time in reading
Scott
Hi Steve, not a problem I have experienced myself, but it is possible to have brackets fabricated to reposition the seat as this is a regular requirement in racing circles.
Most seats in a modern car are secured to the chassis by 2 bolts in each of the 2 runners - therefore 4 in total. What is required is a bracket under each runner that is secured using the existing body holes and allows for the runners to be attached further back. If you search for a race car preparation facility near your location you may well be pleasantly surprised.
Won't hep with the test drive of course, but check around on the site - folks love their S-types.
all s-types have the same wheel base so later ones wont be different
some S-type have adjustable pedals, which will only give you a extra few inches, did you lift the steering column and send the steering wheel in aswell
as mentioned you could make adapter plates.
Yes I did adjust to every possible position and check the electrics were working but I couldn’t get my legs underneath the wheel. I may even take a punt on it and get the owner to test drive it with me-and get him to deliver it to my mechanic to do the work to adjust the seat, not something I’m capable of doing.
So just to keep you updated that basically I cannot for in an S Type, but I saw a nice XJR LWB that’s been parked at my work for ages and didn’t realise the owner was someone I speak to all the time. I asked whether I could sit in it to find out if fitted and low and behold I can.😋
I went to see an XJ8 yesterday which wasn’t the LWB and guess what, can still fit. So I go and pick her up next week after a dent has been taken out. I got a couple of things to do like one of the rear doors only lock manually, and the air suspension fault comes up after driving 10 minutes which is strange it’s not after starting, the heights are fine and rides well, I’ll have a look at the code when I’ve finally collected her.
Hi Scott, excellent, well done you. Hope you are very happy in the world of Jaguar motoring.
If height is fine, you may well find a sensor has a fault.
