I know that there is an old post about this but I have a similar problem. The difference in my case is that the main car battery is new and fully charged and also not only does this alarm sound but it actually does immobilise the car. the car is a 2005 S type 2.7D
So the situation is this: one hot day I heard the beeping noise from under the bonnet of the car. This was not the horn but a high pitched beeping which I had never heard before. Even though I unlocked the car with the fob, it still continued to beep and when I tried to start the engine, although it turned over, it would not start. I then disconnected the main battery and the alarm stopped. After 10 minutes I reconnected the battery but although the alarm did not sound, the engine still would not start.
I then connected my iCarsoft diagnostics and it came up with 7 faults on the engine, including crankshaft position sensor, MAF sensors, Turbo boost solenoid, No 6 cylinder injector and others. This was without the engine running and had previously run perfectly. I then cleared all faults and the engine started normally. When I then ran the diagnostics there were no DTC faults.
Now, if I leave the car locked overnight, the immobiliser has always activated in the morning. Whether the alarm sounded I don't know as I can't hear it from my bedroom. If I leave the car unlocked then it is fine in the morning.
Can anyone advise me as it appears that I cannot access the immobiliser with the iCarsoft LR V3.0
Only SDD/IDS can access immobiliser faults. Then you can remove the battery sounder and strike it off the dealer options. A fault signal from the battery sounder will trigger the main alarm. Diagnostics will tell you if a module is playing up, all in all recommended. Until then you are doing as much as you can.
Posted (edited)
The situation has worsened now as if I try to start the car in the morning, it spins over like crazy but won't start. If I then cycle the ignition on and off about 10 times then it will start straight away.
My thinking was that perhaps the check valve in the tank fuel pump was leaking back but when I removed the delivery pipe from the pump, it was full and the fuel did not disappear from the outlet stub, indicating no leak-back. In any case, with the ignition on, the pump runs continuously so switching the ignition on/off shouldn't be the cure.
This only happened before if I locked the car but now it happens locked or unlocked and depending on the length of time that it has not run determines the number of ignition cycles I have to make. If it is off for an hour then probably only two.
I am still leaning towards a faulty immobiliser but would welcome any constructive comments.
Edited by plaviator
additions
Can the JLR SDD 165 Mongoose access the immobilizer fault codes on my 2005 S Type
No, but SDD 131 and mongoose can do it. As soon as you plug it in it will read the car and send you to 'Legacy' IDS. Apparently this version is easy enough to track down and it has to run on WinXP with the PC date August 2012!
  • 4 weeks later...
Justin, I bought the JLR Mongoose to try and identify the problem.
I installed the program on a windows 7 32bit laptop and it seems to function correctly. At least it finds the vehicle VIN but when I select diagnostics, it starts to get the data but at 13% it stops and won't go further. after a while I get a message to data acquisition could not be completed.
I have tried it many times but always get the same result.
Any ideas?
If you have the mongoose then go to these people to obtain V131. As they say -
131V – this version is the last one which doesn’t require Topix account and you can use programming functions offline. It covers Jaguar 1996-2012 and Land Rovers 2005 – 2012. 131V works only on XP Pro but if you don’t have this old system then we can send you preinstalled version on VMware
https://tools4car.co.uk/product/jlr-ids-sdd-v131-03-jaguarlandrover-diagnostic-software/
______________________
Regarding the battery sounder, remove fuse F7 from the passenger fuse box then lock the car via the key transponder. The arm led will not lite and after 30 minutes the car will not respond to the key fob, it will go into a deep sleep. However the battery sounder will be inactive. If this stops erroneous alarm activation you know this is the basis of your problems. To enter the car after this, unlock the driver door and insert key into the ignition. Re-insert F7 and then set about removing the battery sounder.
You may have more than one fault from the sounds of it
The Alarm and imobiliser are completely seperate, the beeping sound will more than like be the sounder, if its beeping, then its the active sounder, almost all car now at this age the battery backup in the sounder are usually no good and most times they discharge the main battery and cause regular nuisance alarms, this can be proven by just unplugging the active sounder, its in a metal box under the fuse box in the engine bay
The non starting fault sounds like bad glow plugs, turning the key off and on, will restart the glow plug heaters, doing this multiple times will make it start far easier, odds are some of the 6 glow plugs have failed, glow plugs always become a problem this time of year as it get colder, there not needed when the temp is warmer.
to get accurate fault codes and possible remedies on S-type you need to plug it into Jaguar IDS/SDD, SDD is whats compatible with yours and that will give you accurate fault codes
if you need workshop manuals look here http://www.jagrepair.com/
On 11/9/2025 at 11:45 PM, JOE-DOT-COM said:
Hello Joe, thank you for your suggestions. Things have moved on a bit since I last posted and the situation as I see it now is that the longer that the engine is stopped, the harder it it to start. For instance I can stop the engine and it will restart immediately after just a few minutes but if I leave it for 20 minutes then it will need probably 5 tries to start it. If I leave it overnight then it will not start at all. but if I leave the ignition switched on (in tank pump running) for 10 minutes then it will start immediately. My thought was that perhaps there was a check valve that was not closing and pressure was leaking back to tank but now having read the workshop manual I see that there is a system that prevents you from running the fuel tank completely empty. At about 5 ltrs in the tank, it will inhibit starting until the tank is filled again. I am wondering if it is this system that is causing my problem. The funny thing is that no DTC are flagging up
Regarding the SDD, I have one but although it finds my VIN and all the checks are green, when it tries to run the scan it reads the first 2 modules and then stalls at 13%. after about 5 minutes of trying it gives a notice that it is unable to retrieve the data. I can't figure out what the problem is.
If its fuel related it might not cause any fault codes
Have you changed the fuel filter and checked the gasket on  the cover, possible cause
On 11/15/2025 at 11:08 AM, JOE-DOT-COM said:
Joe, if and when it starts, it starts without hesitation and I can drive for an hour, have a cup of coffee then it will stat again and drive home so I can't believe that it is air in the fuel system. It is as if the injectors are being inhibited
I wish that someone could tell me why the SDD diagnostics won't read the data on my car
Hello Justin, The SDD/Mongoose that I have I presume is a Chinese clone. The suppliers said that it must not be connected to the internet or it will not work. Therefore when I try to use it, it has the Red notice in the top right corner saying servrt fault. Is this normal?
    • Jaguar Icons
      • 11 replies
