I have a judder from the car when pulling away and was hoping someone may have some idea regarding this problem ? It has been suggested that it may be a fluid (or lack of it !) problem but would value others ideas. Its a 2000 registered car with 140K onthe clock.
Thanks for reading,
Kim Marsden.
3 hours ago, LairdScooby said:
Manual or auto Kim? Engine, petrol or diesel? Any fault messages on the dash?
Hi Dave, Auto, 3ltr V6 petrol, year 2000. No warning lights on dashboard.
HI
Change the oil, thats got the ford gearbox and uses Standard ATF oil
so cheap and worth changing, usually fixes a lots of problems, especially if the oil is low
What Joe said ^^^^^
I suspect it's had a change before and the wrong fluid was used, alternatively it could simply be the original fluid is old and dirty.
It's surprising how many faults are fluid related.
Also worth checking the wheel balance on the back end and also springs and dampers/shock absorbers and suspension bushes at the back end.
11 hours ago, LairdScooby said:
What Joe said ^^^^^
What Joe said ^^^^^
Thanks for the info. Oil and filter change seems to be the place to start.
All the best,
Kim.
