hi, just joined and I would like to ask for some help. I have an 2004 xk8 convertible which leaks down the front door pillars. Help
hi and welcome
You need to check out the condition of the door rubber, clean them and get some rubber conditioner
Welcome Allan, I had a similar problem on my Volvo C7o, it turned out that sometimes the window did not run squarely in the window runners, could be another thing to look at, if the seals all seem ok, good luck
