Locking issue
Macdonald
Hi Folks,
New to this World, having just purchased my first Jaguar (1999 S Type) a couple of days ago.
I have just noticed today that when pressing the door lock button on the fob, it sounds like doors lock and indicators flash to signal this, but doors remain unlocked. Either seems to be locking and immediately unlocking or not actually locking in first place.
One other small thing is that the dash display reads Boot Open when it is securely locked.
Any advice appreciated!
Hi Folks,
I had a problem few weeks ago after the snow. All my doors would lock after pressing unlock on the remote control. as soon as I pressed unlock I had to open door immediately other wise it would lock again. Last week after a long run to Hull and back it started to work correctly again. I can only assume that water when the snow melted got into some electrical part that operates the doors.
It is now working ok, fingers crossed
The car is not locking because it thinks your boot is open even though it is not, it will try to lock then unlock as it thinks boot is still open, try cleaning locking mechanisam on boot, could just be bad contact, if you can stop dash board saying boot is open my guess is central locking will start working again properly.
 Bought a new locking mechanism, changed over. Lock works no problem manually and remote but dash still reads boot open!!
 This is still preventing all doors from locking. Any ideas folks?
 Latest on this issue - Took the car in today to Straiton's Jaguar in Edinburgh. Following diagnostics check, they discovered 5 broken wires by the passengers footwell.
Wires repaired and it certainly remedied the Boot Open reading.
Problem with the locking however is still the same! On pressing lock, front doors are locking but rear doors remain unlocked. Any further thoughts?
If it locks and unlocks fine with the key then more than likely! When I connected the used one the locks behaved perfectly! I'm going to have another go at it this weekend so will let you know how I get on
Have a look at this
http://www.ebay.co.uk/itm/JAGUAR-S-TYPE-DOOR-LOCK-SOLNOID-O-S-F-DELIVERY-INC-/380630536174?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item589f590fee
